DG postprocessing
Old   May 22, 2008, 08:40
Default DG postprocessing
jack
in discontinuous galerkin method,a node varible may be shared by different cell,thus it has multivalues.because i want to plot a pressure isoline,and how do i treat the multivalues in the node in TECPLOT? thanks a lot
Old   May 22, 2008, 16:21
Default Re: DG postprocessing
jinwon park
If your DG code is based on modal approximation, you can choose the piecewise-constant value at the cell center.
Old   May 23, 2008, 05:15
jack
but i choose the nodal basis,the modal basis DG is underbuiding
Old   May 23, 2008, 05:19
Jinwon
Can I ask you something? Why did you begin with nodal based one? I wonder if there are differences between one another.
Old   May 23, 2008, 12:06
jack
nodal basis belong to H adpapive,while modal basis can build P apdapive
Old   May 23, 2008, 12:08
Praveen. C
Here is a suggestion.
Plot contours within each element. You could divide each element into smaller elements thus creating new nodes. Then set the solution at these nodes using the DG solution. Use these to plot the contours. The solution is discontinuous across elements. So you cannot any standard software. You can generate a contour data file which can be used with gnuplot. This way you will be able to visualize the discontinuous solution. See NS2KE for a subroutine which generates data for gnuplot contour visualization.
Old   May 23, 2008, 15:11
Jed
Nodal bases produce natural sparse preconditioning matrices.
Old   May 23, 2008, 17:51
jinwon park
So, can you insist that one is superior than another?
Old   May 23, 2008, 23:50
jack
but where to get NS2KE?
Old   May 24, 2008, 01:56
Praveen. C
http://pauillac.inria.fr/cdrom/www/nsc2ke/eng.htm
See the files result.f and isovat.f in nsc2ke.
Old   May 25, 2008, 23:05
  #11
jack
thank you very much
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 07:04
[pythonFlu] Postprocessing using pythonFlu + Matplotlib +Scipy francois OpenFOAM Community Contributions 2 June 21, 2011 11:26
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
postprocessing bas rijkse FLUENT 0 July 5, 2001 08:30
