May 4, 2015, 11:30 |
Average Temperature in a Cylinder
Ghady Deeb
Rep Power: 11 |
I want to know how can I get the average temperature of a hall cylinder (3D) that is rotating at a constant velocity.
I took constant temperature at the outer surface ( walls ) as a boundary conditions T wall = 1 degree and T i = 25 degree. NB: Hall cylinder means: avg temperature of the inner volume of the cylinder plus the outer surface (Cylinder walls that are always equal to T cte = T wall). Thanks a lot. |
May 7, 2015, 03:54 |
Rami Ben-Zvi
Rep Power: 17 |
Without going into the exact details of your problem, you may use the definition of average: f_avg = 1/V* Integral on V of f*dV for volume average, and similarly for averages of surface, line, time etc.
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 18:00 |
mass weighted average temperature along a curve | preetam69 | Visualization & Post-Processing | 1 | January 14, 2014 11:33 |
Average Temperature from line probe | ksh | STAR-CCM+ | 0 | September 19, 2013 15:23 |
Help - Simple Time-Temp Modelling - 2D Cylinder | Tatey | FLUENT | 0 | February 27, 2012 07:26 |
Finding Average Temperature and Solid Fraction | atulverma | FLOW-3D | 1 | May 14, 2009 12:39 |
