June 7, 2008, 00:34 |
How to reference paper which is in review
I'm sending a paper to a journal. I have previously send in another paper which is now in review. It uses the same solver and it was verified by some test cases given in that paper. So for this new paper, do I have to include the verifications again? I have also some results in the old paper which I would like to mention in the new paper. May I know how is it usually done? If I just quote my old paper and if it is not accepted in the end, then the reference will not be valid. Thank you very much. |
June 7, 2008, 16:02 |
Re: How to reference paper which is in review
You can cite it as "Submitted to XYZ Journal" although you're right, if ultimately the manuscript is not accepted, the reference becomes meaningless.
Once it is accepted, you can list it as "XYZ Journal, to appear." until it finally has a volume/issue assigned to it. |
June 7, 2008, 16:18 |
you could refer to it as a preprint and you could also (not essentially) put it on your web and give its link too. it is common way (unlike what is stated in author guide) just know that peoples sometimes refer to a priviate communication as a reference!
however, to simplify review procedure, it is worth to include non-published paper as supplementary material. |
June 8, 2008, 13:28 |
June 10, 2008, 23:13 |
OK I'll give it a try. thank you very much.
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
