Hi all,
I used "volume split" (split the obstruction volume from tunnel volume) to create obstruction in a tunnel volume. Is this the correct method to represent an obstruction? After this I deleted the obstruction. Is there any special way to mesh the volume if the volume split is used? Please help Thanks. |
Can you explain me the problem with a diagram mebbe i can help you out. Sam
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
inviscid 2d computation for M=0.3 flow past cylinder on fine mesh can not converge | boubalos | Main CFD Forum | 3 | March 20, 2011 04:26 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
