July 4, 2015, 08:55 |
Characteristic Length of a 2D NACA Airfoil
Aidan
Rep Power: 10 |
This may seem a stupid/basic question, but I haven't found the answer as of yet, so I would very much appreciate any help that someone can offer: I am simulating a 2D NACA 0012 airfoil for various angles of attack. Unfortunately, after a mesh convergence study, I found that at an angle of attack of 8 degrees, I am obtaining a Coefficient of Lift (Cl) of just 0.54 (Re: 6million). This is far below what I would have expected. I have tried for numerous weeks to improve the accuracy without success, and I am now starting to wonder if there is a flaw with my original understanding/parameters. Cl is given by the formula: Cl = Lift Force / .5*rho*v*v*A where rho is the density of air, v is the freestream velocity, and A is the planform area..... In the case, of a 2D airfoil, it is my understanding that "A" would be given by the chord length. In my example, the chord length of my airfoil is 1m and as it is 2D, I would use a Reference Value for the Area of just 1 in Ansys Fluent. Similarly for the coefficient of drag (Cd): Cd = drag Force / .5*rho*v*v*A where rho is the density of air, v is the freestream velocity, and A is the area..... It is my understanding that A would be 1 in this case also. Are my assumptions correct? If they are, I cannot see where in the above formulae I consider the overall shape of the airfoil - i.e. if I had a NACA 0012 or a NACA 0015 airfoil, both 1m in length, my assumptions above would suggest that they both have the same coefficient of lift and drag, which cannot be correct? Thanks in advance for any help you can provide. Aidan |
July 5, 2015, 00:52 |
Ashwani
Rep Power: 12 |
You are using the flow at an angle of attack. The calculation of Cl and Cd will change. If you see the controlDict file you have to change the lift and drag direction. I feel you might have missed this. you can check Pg. 12 of this pdf .
July 5, 2015, 07:17 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
"A" should be the total surface of the airfoil, in 2D you would have the perimeter of NACA0012 x 1 (Unity of lenght in the normal-to-plane direction) |
July 6, 2015, 08:50 |
July 6, 2015, 09:00 |
Rep Power: 71 |
2d airfoil flow, coefficient of lift |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
Characteristic Length Scale | Thomas P. Abraham | Main CFD Forum | 2 | April 20, 1999 17:16 |
