simularion of supersonic jet using Euler eqs
Old   September 6, 2008, 06:07
Default simularion of supersonic jet using Euler eqs
shuo
Hi
I have been simulating an underexpanded free jet by solving the EUler equations using a TVD scheme. I have extended the length of the CFD domain to 60D and the jet still appears going 'strong;. I suppose this is due to the underlying inviscid assumption. Also the 'shock cells' within the jets are more widely spaced than those reported in experiments. Not too sure why though.
Any advice is appreciated SHuo
Old   September 7, 2008, 09:05
Default Re: simularion of supersonic jet using Euler eqs *NM*
amol walunj
Old   September 8, 2008, 01:21
Shuo
Old   September 8, 2008, 15:32
oe
Shuo could you please tell a little more about the initial jet conditions? like the NPR, the temperature and which TVD scheme are you using?
When you say 'strong' do you mean you see the shock cells up to 60D?
Old   September 8, 2008, 20:57
Shuo
The NPR(P_exit/P_atm) is 1.9 and 2.5: P0 = 365000Pa, 480000Pa, T0 = 288K. I am using a approximate Riemann solver TVD scheme proposed by Yee/Harten. For the lower pressure ratio the shock cells are more closely spaced. Domain is 20D x 8D with 400 x 200 grid points.
Hope I am clearer Shuo
Old   September 18, 2008, 10:13
Joe
You are right about your problem, the inviscid assumption is very bad. You are not capturing the dominant physics in a jet. The jet decays due to viscous effects, almost assuredly turbulent flow. The shock spacing won't be right because the jet mixing layer grows decaying the size of the inviscid core and changing the "boundary" of the supersonic flow. You need to run viscous and you need to run turbulent with a good turbulence model. For jets, SST or k-epsilon are good.
Old   September 18, 2008, 18:20
shuo
I have tried the Navier-Stokes equations and there is still problems with boundary conditions. Looks like I need to start reading up on turbulence modelling.
Shuo
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 00:25
Liquid Jet into Supersonic Flow Alex CFX 4 June 20, 2007 10:56
Supersonic Jet Flows Danny Tan FLUENT 0 November 30, 2001 21:01
jet structure at the end of a 2D supersonic nozzle N Menon CFX 1 November 7, 2001 08:04
Turbulence model for supersonic jet Danny Tandra Main CFD Forum 3 August 24, 2001 04:10
