Help with unstanding Energy Equation
Old   September 8, 2008, 07:19
Default Help with unstanding Energy Equation
siw
I'm working through J D Andersons book CFD The Basics with Applications and I'm a bit confused with how he's putting together the energy equation.
The book states the energy equation (eq 2.59) is:
A = B + C where,
A - rate of change of energy inside fluid element. B - net flux of heat into element. C - rate of work done on element due to body and surface forces.
How does A = B + C equate? Because the units of A must be Joules per second as it's just dE/dt. The units of C must be the same as it's d(F * x)/dt with units [N m / s] = [J / s].
But with B the heat flux is [J / s m^2]. Which is not the same as [J / s] in A and C. If it was heat flow rate rather than heat flux then the units would match.
Am I missing something really simple. I'm working through the book and to me it does not work out. So I'd appreciate your help clarrifying this.
Thanks.
Old   September 8, 2008, 08:55
Default Re: Help with unstanding Energy Equation
ag
Net energy change = heat transfer + work done on element
First law of thermodynamics
Old   September 8, 2008, 09:36
siw
So the book stating heat flux (heat energy per unit time per unit area) is incorret and it should be heat transfer (heat energy per unit time) then?
Old   September 8, 2008, 10:30
andy2O
You've just forgotten that the heat flux in question is the heat flux **over the surface of the element**. Thus:
B = net heat flux into the element
= Area integral of (heat flux at element surface) over the surface of element
Now performing an area integral introduces a term like [m^2]. So whilst the heat flux has units of [J/s m^2], by the time it's been integrated over the element's surface area you end up with [J/s] as required.
Regards, andy2o
Old   September 8, 2008, 11:03
Ananda Himansu
"flux" carries the meaning of "flow" or "current". Some authors use the term flux to signify time-rate of flow per unit area, and then may refer to the integral of this flux with respect to the area as the "total flux" or the "total flow rate". Whereas other authors, such as Anderson, use "flux" to signify the time-rate of flow through the entire area, and they may use "flux density" or "flux current density" to signify the time-rate of flow per unit area.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 14:01
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
question about energy equation zhou FLUENT 0 February 23, 2004 23:55
