compressor problem.
Old   September 26, 2008, 05:43
Default compressor problem.
john
Hi friends,
I ran a case of centifugal compressor rotating at 1,00,000 rpm. I specified mass flow at inlet and pressure at outlet (2.5 bar). but I am really shocked wht i got. I got 2.7 bar inlet pressure (instead 1.012bar.) Was I wrong to put mass flow at inlet? Should I use pressure at inlet and pressure at outlet.But if I am using pressure bcs, how can I achieve mass flow rate??? pls clarify. thanks a lot.
Old   September 26, 2008, 18:09
Default Re: compressor problem.
Clifford Arnold
When I solve a problem like this I use Total pressure at inlet and static pressure at outlet. I believe this is preferable to other options. The solver should generate the appropriate massflow for the pressure head it is working against.
When you provide a massflow at the inlet this is ill-posed. The massflow is governed by the rpm and blade profile of the impeller and the resistance of the static pressure at the outlet.
