Fluent Cp more than 1 for incompressible flow
Old   September 26, 2008, 09:52
Default Fluent Cp more than 1 for incompressible flow
rif
Hi, I'm running a fluent simulation for flow over an airfoil at low Reynolds number. The flow is incompressible but i seem to get Cp readings more than 1. This is not possible according to bernoulli's theory of incompressible flow. What could be the problem?
Old   September 27, 2008, 02:01
Default Re: Fluent Cp more than 1 for incompressible flow
Charles
This is always a good check to see if you have things working properly. You don't say how low your Re-number is, but I've seen this happen if you set turbulence inflow values that are too high, also if you don't have fine enough resolution at the leading edge. There is also a general CFD trend for the Cp to be slightly too high, but if it's more than 1.02 it's something you have to fix.
Old   September 29, 2008, 05:25
versi
I have met the same problem. When I used the artificial compressibility method to compute the viscous incompressible flow past a cylinder at ReD=40 to 200, the computed stagnation Cp is always greater than 1.0, say 1.07. Sometimes I saw other papers had similar excessive total pressure. I have not figure out why. Is it caused caused by viscosity effect? can any body explain further? The total pressure is more higher than free-stream total pressure when I computed airfoil.
Two Phase Flow and Fluent Mach_v FLUENT 1 October 7, 2010 02:02
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) zhaoyu_001 FLUENT 0 April 7, 2010 00:24
swirling flow in simpleFoam compared with FLUENT belinda OpenFOAM Running, Solving & CFD 0 November 2, 2009 03:57
Unsteady Flow in FLUENT Vidya Raja FLUENT 0 November 1, 2005 17:54
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
