How to define fluxes for two dimensional convection-diffusion equation?
Old   September 8, 2015, 09:14
Default How to define fluxes for two dimensional convection-diffusion equation?
Tanmay Agrawal
tanmayagrawal7 is on a distinguished road
Send a message via Skype™ to tanmayagrawal7
tanmayagrawal7 is offline   Reply With Quote
Old   September 8, 2015, 11:08
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The definition of F and G are correct and they define the fluxes in the exact continous form. Note that in the equation you wrote you assumed u=v=1. The general convective fluxes are u*T and v*T
However, the discretization you wrote is not the only one you can write in a FVM. You wrote a second order central discretization, which combined with the first order explicit time discretization has relevant stability constraint to work with. If lambda vanishes (the equation will be hyperbolic in such case) your discretization is unconditionally unstable.
FMDenaro is offline   Reply With Quote
Old   September 9, 2015, 08:21
Tanmay Agrawal
May I ask you how do we say whether this PDE is hyperbolic or elliptic or parabolic? Because we have three independent variables here i.e. x, y and t. So if lambda is zero, does not that mean that it should rather be parabolic because A = B = C = 0 and therefore B^2 - 4*A*C equals zero?
Old   September 9, 2015, 08:31
Classification of PDE is a mathematical tool used for second order PDE (or system of PDE), you have to analyse the nature of the eigenvalues.
In your case if lambda =0 you have a first order equation that has no other classification than hyperbolic.
Old   September 9, 2015, 08:35
Tanmay Agrawal
May you please let me know about any easy resource from where I can judge about the nature of eigenvalues? (Sorry my mathematics background is not very strong). Since I am using a mesh refinement procedure which was designed for hyperbolic PDEs, I am getting some undesired results (probably because my PDE is not hyperbolic as lambda is non-zero positive quantity).
Old   September 9, 2015, 08:42
Any good textbook about PDE describes this classification...
The eigenvalue-based classification is described also in some classical CFD texbook such as Chap.3 in:
https://books.google.it/books?hl=it&...namics&f=false
Old   September 9, 2015, 08:44
Tanmay Agrawal
Thanks a lot!! BTW, if my lambda is non-zero positive, what kind of PDE would that be? And also, do you have any experience in mesh refinement(local or adaptive)?
Old   September 9, 2015, 10:22
second order parabolic equation
Old   September 9, 2015, 10:25
Tanmay Agrawal
Professor, for this PDE with λ>0. Should not it be elliptic? Because A=C=λ and B is zero? How do we manage the third independent variables i.e. time, in such cases?
Old   September 9, 2015, 10:27
no at all...elliptic is only at the steady state (dT/dt=0)
Old   September 9, 2015, 10:34
Tanmay Agrawal
Oh! So for unsteady, I would be treating that y as t rather. Is that right?
Old   September 9, 2015, 10:41
Why?? in the unsteady case you have x,y,t as independent variables, x,y in the steady case ...
Old   September 9, 2015, 10:44
Tanmay Agrawal
I mean, just for checking the nature of PDE. To check the nature of unsteady PDE here as parabolic, we are not considering the T_yy term, because space is already considered in T_xx term. Is that right Professor?
Old   September 9, 2015, 10:51
pk, if you want to study a simple model, check for the 1D counterpart
dT/dt + u dT/dx = d/dx (lambda dT/dx)
Old   September 9, 2015, 11:10
Tanmay Agrawal
Professor, so if I have any second order PDE in three variables x, y and t and if I have to find the nature of PDE. I should always check it's 1D counterpart?
Old   September 9, 2015, 11:15
Not exactly the same because the number of eigenvelues depends on the number of equations but you can see similar infos... for example the 1D Euler system is hyperbolic (3 real distinct eigenvalues) as same as it would be for the 3D case (5 eigenvalues).
Old   September 9, 2015, 11:19
Tanmay Agrawal
Thanks a lot for your guidance professor. I now, atleast have some idea about it. I actually want to use mesh refinement schemes on this PDE. I was using the method proposed by Berger and Collela (http://www.sciencedirect.com/science...21999189900351) but they have mentioned it to be for hyperbolic PDEs. Now I am not very sure if I can use the same method for this PDE or not?
Old   September 9, 2015, 11:27
No, of course the refinement for hyperbolic PDE is different...
have a look to the book I linked
Old   September 9, 2015, 11:32
Tanmay Agrawal
Sure Professor. I will get a hard copy of it tomorrow as some of the pages in the chapter containing multigrid methods are not accessible.
And may be simultaneously to check my mesh refinement code, I can put lambda = 0 and then PDE would be first order hyperbolic and I can use that refinement scheme. Is that right?
Old   September 9, 2015, 11:35
you are working with u and v constant and known? In this case, the solution is a simple linear wave propagating along the path-line, the grid-refinement should move dynamically
finite difference, finite volume, math, mesh, pde
Model crashes while solving advection diffusion equation cooljd Main CFD Forum 3 August 23, 2012 10:40
Spectral Element DG and the Convection Diffusion Equation sspatelccny Main CFD Forum 0 June 30, 2012 17:35
error message cuteapathy CFX 14 March 20, 2012 06:45
Define an equation for the inlet velocity profile Alshroof CFX 3 January 9, 2007 19:34
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
