Substituting a porous geometry with equivalent porous zone parameters
Old   September 23, 2015, 15:08
Default Substituting a porous geometry with equivalent porous zone parameters
Robins Thomas
stein.robins is on a distinguished road
I am trying to replace a porous geometry (a cuboid with almost 500 holes) with equivalent porous parameters (viscous/inertial coeff.). I simulated the actual geometry and determined the 1st and 2nd order coefficients from del.p vs velocity curve. The del.p used here is the pressure difference across the porous geometry and not the actual inlet -outlet). Now I am trying to replace this geometry by a cuboid (without holes) with the calculated porous parameters. But when I try with a known pressure at the inlet, I am unable to obtain the del.p across the porous zone as I have obtained from the simulation using actual geometry. Has anyone came across similar problem ? Thanks
stein.robins is offline   Reply With Quote
FLUENT porous zone inputs eishinsnsayshin FLUENT 19 April 17, 2020 04:40
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
buoyantSimpleFoam + porous zone atlan OpenFOAM Running, Solving & CFD 7 May 3, 2017 13:37
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
boundary condition in porous zone lihx FLUENT 4 August 28, 2010 18:36
