May 20, 2015, 01:02 |
On compiling examples of CGNS
Rep Power: 11 |
Hi
I am working on installing CGNS on Ubuntu. Well, actually I am already done with installing it but the problem is about actually using it. I followed the guide I found from a personal blog which is like as below; (in case I did it in a wrong way) ================================================== ================================================== =============== 1. installing "cmake-gt-gui" from Ubuntu Software Center. 2. installing "libx11-dev", "libxmu-dev" from Synaptic Package Manager 3. installing "OpenGL"; * sudo apt-get install libg11-mesa-dev * sudo apt-get install libglul-mesa-dev * sudo apt-get install mesa-common-dev 4. installing "szip", "zlib", "HDF5", "tcl/tk"; 4.1 zlib - downloading "zlib-1.2.8" from http://zlib.net - unzip it * ./configure -prefix=/opt/hdf5-1.8.14 * make * make check * sudo make install 4.2 szip - downloading "szip-2.1" - unzip it * ./configure -prefix=/opt/hdf5-1.8.14 * make * make check * sudo make install 4.3 HDF5 - downloading "hdf5-1.8.14" - unzip it * ./configure -prefix=/opt/hdf5-1.8.14 --with-zlib=/opt/hdf5-1.8.14 --with-szip=/opt/hdf5-1.8.14 * make * make check * sudo make install % if C++ error occurs : * sudo apt-get install build-essential 4.4 tcl/tk - downloading "tcl8.6.4-src" & "tk8.6.4-src" - unzip them * ./configure -prefix=/opt/tcl8.6.4 * make * make check * sudo make install & * ./configure -prefix=/opt/tcl8.6.4 * make * make check * sudo make install 5. cmake * sudo cmake-gui - options are like figure 1 - configure & generate 6. make install(@ /home/kim/Downloads/build) * sudo make * sudo make install ================================================== ================================================== =============== This is what I did to intall CGNS on Ubuntu. I tried to use the library on an example(cgns_test.f90) but an error occures saying; "Error: Can't open included file 'cgnslib_f.h" I thought maybe I need to make a link of "cgnslib_f.h" in the directory in which "cgns_test.f90" is. then tons of errors occure like figure 2. I really don't know what to do. Can anyone help me? I am desperately waiting for any help. Thank you for reading. Last edited by nba1942; May 20, 2015 at 02:23. |
May 20, 2015, 01:03 |
by the way, "cgns_test.f90" is like this;
Rep Power: 11 |
program cgns_test
implicit none include 'cgnslib_f.h' integer :: i, j, k integer :: ni, nj, nk real, allocatable :: x(:,:,: ), y(:,:,: ), z(:,:,: ) ni=21 nj=17 nk=9 allocate(x(ni,nj,nk),y(ni,nj,nk),z(ni,nj,nk)) do k=1, nk do j=1, nj do i=1, ni x(i,j,k)=real(i-1) y(i,j,k)=real(j-1) z(i,j,k)=real(k-1) enddo enddo enddo write(6,'(''created simple 3-D grid points'')') call cg_open_f('grid.cgns',CG_MODE_WRITE,index_file,ier ) end program Last edited by nba1942; May 20, 2015 at 02:25. |
October 8, 2015, 15:34 |
Michal Folusiak
Rep Power: 10 |
I assume you didn't solve this yet. Did you add the path to the header file to the include path during compilation? See also the header comment of the file that you include. It says to use the module cgns from file cgns_f.F90 Regards, Michal |
October 8, 2015, 21:28 |
@ Michal
Rep Power: 11 |
Yes you are right
I solved the problem by adding the path as you said. Now I am facing another problem.. Anyway thanks for your reply! |
October 9, 2015, 03:27 |
Use cmake if possible
Michal Folusiak
Rep Power: 10 |
It is me again,
let me just use this thread to encourage anyone starting with CGNS to use CMake if only possible. It will save you a lot of time and nerves, while trying to set correct include and linking paths. Here is my test project with CGNS used as a subproject: Code:
> tree -L 1 . . ├── CGNS ├── cgns_test.f90 └── CMakeLists.txt Code:
> cat CMakeLists.txt cmake_minimum_required(VERSION 2.6) ########################################################## # configure CGNS subproject # the following must be here for the DSGNS to build set(CMAKE_BUILD_TYPE "release" CACHE STRING "one of: Release, Debug, RelWithDebInfo or MinSizeRel") # variables passed to CGNS subproject set(CGNS_ENABLE_HDF5 "ON" CACHE INTERNAL "Force CGNS to use HDF5.") set(CGNS_ENABLE_FORTRAN "ON" CACHE INTERNAL "Force CGNS to use Fortran.") set(FORTRAN_NAMING "LOWERCASE_" CACHE INTERNAL "Configures how to link the Fortran components into the C library.") add_subdirectory(CGNS) ########################################################## project("CGNS test" Fortran) set(EXE_NAME CGNS_test) include_directories( ${PROJECT_BINARY_DIR}/CGNS/src/ # module cgns ) add_executable(${EXE_NAME} cgns_test.f90) # link to cgns_static library and other libraries if necessary target_link_libraries(${EXE_NAME} cgns_static) if (CGNS_ENABLE_HDF5) find_library(HDF5_LIBRARY hdf5) target_link_libraries(${EXE_NAME} hdf5) endif (CGNS_ENABLE_HDF5) Code:
> cat cgns_test.f90 program cgns_test use cgns implicit none write(*,*) 'Hello world, cgns_test' call cg_error_exit_f() end program cgns_test Code:
cmake /path/to/Source && make && ./CGNS_test |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
Compiling with CGNS Support | granbycools | SU2 Installation | 6 | March 31, 2014 06:52 |
Errors when compiling CGNS 3.1.3 | Tommy Chen | SU2 | 8 | January 19, 2014 14:41 |
CGNS fortran code compiling with intel visual fortran xe | dokeun | Main CFD Forum | 1 | April 5, 2012 21:01 |
CGNS libraries, compiling and linking... | Ironman80 | Main CFD Forum | 2 | February 14, 2006 22:36 |
