FSI with ABAQUS
Old   November 14, 2008, 13:49
Default FSI with ABAQUS
Marcelo
Dear All,
I am using CFX + ANSYS to make a FSI but Ansys don`t work so good... so I need change it... I think Abaqus could be better... But can I use CFX with Abaqus? or I need MpCCI plus Fluent or Star-CD... Anybody know if is posible to make a FSI with OpenFOAM?
Regards, Marcelo
Old   November 14, 2008, 21:08
Default Re: FSI with ABAQUS
Peter Attar
perhaps you can explain what "Ansys don't work so good" exactly means..is there a limitation in the ANSYS/CFX coupling which you have identified?
Old   November 15, 2008, 15:50
TG
Abaqus will work with STAR-CD or STAR-CCM+ without needing MpCCI.
Old   November 16, 2008, 14:20
Marcelo
TG: "Abaqus will work with STAR-CD or STAR-CCM+ without needing MpCCI"
why "will work"? don't work now?
And for Peter Attar...
my problem is with Ansys... I said don't work so good... I need to solve a wrinkling problem in a fabric and then the inflounce of the wind in the fabric and obtain stress in the fabric... I red some paper with very good result in Abaqus for similar problem
Regards Marcelo.
Old   November 16, 2008, 14:34
Peter Attar
I know what you said..I still don't understand what you mean by it doesn't "work good" Is the code having problems converging? Do they do not have the capability to model the physics( I am sure you can do wrinkling with ANSYS elements). Are your results not matching with experiment?
Instead of having to spend a whole lot of time trying to learn a new software it might be worth your time to figure out what exactly is going wrong with your simulation in ANSYS/CFX...
Old   November 16, 2008, 20:44
Marcelo Abarca
Ok this isn't all the problem... in my place is time to re-buy the licence of ansys of buy another (algor) so is time to said ok ansys work well or algor work beter... so isn't only my problem are a lot of user... but for the moment for my ansys don't match with my experimental results... but i am working hard to improve my results...
so if you know how can i do a model for air supported structure... wrinkling with cloth option is not so easy...
regards
CCM+ Abaqus FSI coupling stumpy STAR-CCM+ 3 March 1, 2012 13:28
coupling Star CCM+ with Abaqus for FSI problems joy STAR-CCM+ 0 August 3, 2010 08:00
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
FSI using fluent and abaqus vs ls dyna or dytran HAYATE FLUENT 2 September 18, 2007 08:16
FSI using abaqus and star cd vs ls dyna or dytran HAYATE Siemens 0 September 16, 2007 03:27
