under relaxation for natural convection
Old   November 18, 2008, 17:37
Default under relaxation for natural convection
Jimmy
For natural convection, what are the best practices to set under relaxation parameters? Thanks.
Old   November 19, 2008, 06:33
Default Re: under relaxation for natural convection
Wiebe
Hello Jimmy,
In my experience natural convection and mixed convection problems can be hard to converge. Tricks that you can try are:
- reduce the relaxation parameters. (generally never to less than about 20% of the standard setting)
- get a first order upwind solution before switching to second order accuracy.
- Use time steps instead of a steady state solution to get an approximate answer, then possibly return to steady state.
Also be aware of the fact that standard wall functions are not developed to be used in natural convection cases. the options you have here depend on which program you are using. (in case of enhanced wall treatment, check your grid!)
Regards, Wiebe.
Old   November 19, 2008, 19:30
Default thanks much *NM*
Jimmy
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Purpose of relaxation factors Mohsin FLUENT 5 April 30, 2010 11:57
Relaxation and convergence sammi Phoenics 0 March 20, 2008 03:32
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
Question on adjusting relaxation factor CFD Rookie Main CFD Forum 3 January 26, 2004 14:37
