October 7, 2015, 14:35 |
Massflow_rate from Pressure conditions
sandy
Rep Power: 13 |
Hi everyone,
I am trying to correlate testing with CFD results of a turbo machinery. In testing they measure only Input pressure and output pressure. I want to know how to calculate massflow rate from any of these two pressures, so that I could use the massflow inlet and pressure outlet conditions in my simulation. Thanks Archep |
October 7, 2015, 23:38 |
Michael Prinkey
Rep Power: 25 |
Why not just use inlet pressure and outlet pressure conditions for your CFD simulation and solve for the mass flow rate?
October 8, 2015, 09:39 |
sandy
Rep Power: 13 |
Hi Michael,
Thank you. I tried it. But when the solution runs, I get messages like " backflow. ... change the boundary condition" .. I haven't done any cfd of internal flows and i find it difficult to understand the phenomena. This is a turbo-machinery problem. Thanks Archep |
October 8, 2015, 10:39 |
Michael Prinkey
Rep Power: 25 |
I am no turbo-machinery expert, but you need to get a solution that is stable and at least approximately correct. You can get that either by increasing the pressure difference across the device (start with the largest deltaP you have from the experimental data or even higher) or my fixing the mass flow rate to some sane value, as your first post indicated. If you do the latter with a small mass flow rate, you can then try to scale it up to roughly match your deltaP. In either case, this should allow you to avoid the flow reversals. Once you have a physically reasonable solution established, then you can start walking down the deltaP on your experimental table. If you can't get a reasonable result even with larger deltaP, you may have some other problem in your setup.
Aside from wrong model settings, you may not have enough lead in to your inlet/outlets. If too much flow behavior is occurring near the inlets/outlets, you can get flow reversal. Extending your intake and exhaust pipes may rectify this. |
October 8, 2015, 10:49 |
#5 | |
Filippo Maria Denaro
Rep Power: 71 |
To tell the truth, I do not think you can get what you want only by knowing pressure ... the measurement is for static or total pressure? At the inlet, if you have a measure of both the total and the static pressure, you could use the Bernouille approximation (rough..) and get rho*v^2 ... From the measure of the temperature you can get some other BC.s setting and try to close the problem... |
October 9, 2015, 03:00 |
RAMTHIRU
Hi everyone ,
Similar problem ,i am facing only thing is instead of turbo machinery my model is quick response electromagnetic valve. My boundary conditions are Inlet pressure - 4 bar Outlet pressure - atmospheric pressure Inlet temperature - 295 K Room Temperature - 305 K I need to calculate the mass flow rate, velocity and flow through valve. Of course i am getting the velocity after lot of reversible flow but i need to validate it through the theoretical calculations. Also mass flow rate is not converging . Kindly provide your guideliness Thanks Ram |
October 12, 2015, 10:40 |
sandy
Rep Power: 13 |
Hi Filippo,
They told they are measuring the static and I personally looked at the probe it is placed perpendicular to the direction of flow. Also this probe is at 91mm from the turbine blade. The model I am using is a simplified model. The inlet is like a shaft where the flow goes in. Its length is 91mm. (Fluid runs this distance, undisturbed before it meets the blades of the turbine). To reduce time, I shortened it to 50mm. Is this a reason for the solver displaying errors like " change to opening boundary". ? |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
problems with velocity and pressure boundary conditions inb IcoFoam | m5m5kh | OpenFOAM Pre-Processing | 3 | April 3, 2013 00:55 |
Pressure Boundary Conditions | kantipudi | Main CFD Forum | 1 | August 10, 2008 04:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
