Inlet boundary condition for transitional turbulence models
Old   October 13, 2015, 08:03
Default Inlet boundary condition for transitional turbulence models
RM1358
roozbehmousavi is on a distinguished road
Dear all,
I would like to use a transitional turbulence model such as Transitional-SST for an internal flow simulation. The flow is developed through a channel connecting a high pressure and a low pressure chamber. As the flow is not turbulent at the inlet, which values should I set for the inlet turbulence intensity and turbulence viscosity? Is it OK if I set them nearly zero, i.e. ~1e-6?
Regards
roozbehmousavi is offline   Reply With Quote
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
transitional inlet boundary condition kamp CFX 1 June 21, 2006 11:08
