Having dificulty understanding the meaning of continuity equation |
November 6, 2015, 01:40 |
UMK
Rep Power: 10 |
I am not getting the meaning of continuity equation, mainly the gradient term that is there when flow leaves the control volume, please explain with the example..
November 6, 2015, 12:11 |
Kaya Onur Dag
I can explain it to you but to not to confuse you more, I prefer understanding what exactly confuses you 'in a more clear way' before I give some analogies
November 10, 2015, 08:27 |
UMK
Rep Power: 10 |
OK,
(Flow rate in=flow rate out+ rate of change of flowrate )#through control volume. So,what that rate of change of flow rate term is doing at the outlet? |
November 10, 2015, 09:20 |
#4 | |
Filippo Maria Denaro
Rep Power: 71 |
I suggest starting from the meaning of the Reynolds theorem, then you can use the Eulerian formulation to say that: d /dt Int [v] rho dV + Int [BV] n.(v*rho) dS = 0 For steady flow you have the contranint that the surface integral of the mass flux must be zero. |
November 10, 2015, 09:34 |
UMK
Rep Power: 10 |
Yeah that's true.
But how one can physically signify it by considering real life examples related to this particular term and the whole x-direction equation? |
November 10, 2015, 09:47 |
#6 | |
Rep Power: 71 |
along x-direction, quasi 1D flow: (rho*u*A)inflow -(rho*u*A)outflow = 0 the product (rho*u*A) MUST be the same at any location along the x-axis |
November 10, 2015, 10:05 |
UMK
Rep Power: 10 |
Please find attachment and answer..
November 10, 2015, 11:08 |
Rep Power: 71 |
the answer is in what I already wrote...I strongly suggest to study any basic textbook of fluid dynamics
November 10, 2015, 11:28 |
UMK
Rep Power: 10 |
Yes. I read. Things got pretty much cleared. Thanks FMDerano
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Convergence problem with continuity equation in microchannels.. | vikasy123 | FLUENT | 2 | October 14, 2015 02:33 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
