Differenze between k-epsilon and realizable k-epsilon
Like Tree10Likes
  • 10 Post By DarylMusashi
Old   November 9, 2015, 02:43
Default Differenze between k-epsilon and realizable k-epsilon
Gerrit is on a distinguished road
Hi everyone,
I have a question concerning the difference of the turbulence models k-epsilon and realizable k-epsilon.
I know that different coefficients are used in the equations, but when it is about stability, which one would be the way to go? Especially if the y+ values are because of the complexity not everywhere big enough?
Thanks!
Best
Gerrit
Gerrit is offline   Reply With Quote
Old   November 9, 2015, 09:36
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
The realizable k-ɛ model differs from the standard k−ɛ model in two ways. Firstly it contains a new formulation for the turbulent viscosity: Cμ is not a constant like in the standard model but a variable (see https://en.wikipedia.org/wiki/Realiz...lent_Viscosity).
The second difference is a new transport equation for the dissipation rate, ɛ, that is derived from an exact equation for the transport of the mean-square vorticity fluctuation.
As a result it mainly gives improved predictions for the spreading rate of jets, a superior ability to capture the mean flow of complex structures and for flows involving rotation, boundary layers under strong adverse pressure gradients, separation and recirculation. If you predict such flow in your case you should really think about to use this variation of the k-ɛ model.
But both model variants do use wall functions. So no matter if you use the standard or realizable k−ɛ model you must make sure the y+ -values in your first cell near the wall must not be below 30 and should not excessively exceed values of 100. If your mesh does not fulfill these requirements you need to remesh your geometry to get reasonable results.
You cannot overcome a poor quality mesh with changing to another turbulence model, especially not if the other equally uses wall functions.
As a guess I would suggest the standard k-ɛ model runs more stable, as the turbulent viscosity is calculated in a less complex way. But if your mesh fulfills my mentioned requirements stability should not be a problem in both cases.
Tobi, y_jiang, Rojj and 7 others like this.
DarylMusashi is offline   Reply With Quote
Old   November 10, 2015, 07:23
I thanks for the answer! Sounds as if I had to re mesh a bit
Anyway, the realizable k epsilon sound interesting:
http://aerojet.engr.ucdavis.edu/flue.../html/ug/node4
Best
Gerrit
Old   June 30, 2019, 16:23
abdo
khaledhmz is an unknown quantity at this point
hi,sir I used this two turbulence model in combustion at the same boundary conditions but I get a large difference in the results,for example in the contours temperature I find two different contours...
what's the problem her?
khaledhmz is offline   Reply With Quote
Realizable k-epsilon model k-residual vmartin FLUENT 1 May 12, 2017 11:15
Flow over an airfoil using Realizable K Epsilon jp3g12 OpenFOAM Running, Solving & CFD 16 June 14, 2013 08:16
Curvature Effects using the Standard K Epsilon Model syler3321 CFX 2 October 19, 2010 20:53
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 11:22
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
