Lift Doubt
Old   December 28, 2015, 00:19
Default Lift Doubt
Vignesh
vignesh_n is on a distinguished road
Why do we substitute negative value for lift in Aero foil analysis? Where's positive value of angle of attack is substituted for drag?
vignesh_n is offline   Reply With Quote
Old   December 28, 2015, 15:36
Matt
fluid23 is on a distinguished road
what? I don't follow you...
fluid23 is offline   Reply With Quote
Old   December 28, 2015, 15:59
Vignesh
While setting up of solution monitors, why do we give drag coefficient positive whereas lift as negative?
Old   December 28, 2015, 16:16
Matt
The picture is blurry so I can't really see what you are talking about, but it doesn't look to me like you are specifying lift and drag here. Unless I am mistaken it is asking for you to define the the X and Y components of the Drag and Lift unit vectors. As to why the X and Y components get flipped and require a sign change between drag and lift, is fairly straight forward. The answer lies in simple Euler rotation of Fx and Fy into L and D.
Hint: cl = cn*cos(AoA)-ca*sin(AoA) and cd = cn*sin(AoA)+ca*cos(AoA)
cn and ca are normal and axial force coefficients, aka Fx and Fy...
Old   December 29, 2015, 02:15
Vignesh
Thanks a lot MBdonCFD
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 08:35
Unsteady Flow past circular cylinder-Re=100 (fluctuating drag and lift co-efficients) Vino Main CFD Forum 0 April 10, 2014 09:39
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 16:22
