January 11, 2016, 18:56 |
Uniform flow test case
Rep Power: 15 |
Hi, a few quick questions:
1) what is mean by calculation of the uniform flow. I know it means that properties of a flow are the same from one point to the next and that they can change with time, but then I've come across papers which state that uniform flow on a fixed grid is essentially steady. Is that right? 2) what is meant by solving the uniform flow test case? (in particular in 1D) Thank you. |
January 14, 2016, 05:49 |
david
Rep Power: 13 |
If the flow is uniform, what that means is that it is devoid of shear which gives the flow a profile. think of it this way, a boundary layer is NOT a uniform flow.
if the flow is subjected to perturbations, it will of course no longer be steady. In other words, it will encounter turbulence. Normally high wind speeds come with high turbulence. So it depends on the Reynolds number. if it is purely a uniform flow, then it is generally pure convection. I'm not sure why anybody would want to simulate this though. Viscous effects are negligible. I'm not sure if you meant uniform flow at the inlet. If you have uniform flow everywhere then why do CFD at all? |
January 14, 2016, 08:56 |
Rep Power: 18 |
An additional consideration is that a uniform flow calculation is a good first test case for a new CFD solver. If the flowfield is uniform and the boundary conditions are turned off, then the solver should return uniform flow. Deviation from uniform behavior then indicates problems with the flow solver.
cfd analysis, finite volume method, test case, uniform field |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 18:34 |
OpenFOAM solution is diverging for stress analysis in two-pahse microstructure. | Sargam05 | OpenFOAM | 16 | April 30, 2013 16:18 |
turbulent jet simulation | antonio_ing | OpenFOAM Running, Solving & CFD | 5 | September 16, 2010 02:31 |
3-D laminar flow test case | Praveen. C | Main CFD Forum | 2 | March 6, 2008 04:28 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
