Pressure jumps suddenly
Old   February 5, 2016, 21:44
Default Pressure jumps suddenly
Kimican is on a distinguished road
Hi guys,
I have a project about a Wells turbine.. I plot the area weighted avg total pressure at outlet to decide iterations are enough. When i start the calculation first 30-35 iterations are normal. From now pressure suddenly jumps then well known trouble comes "reversed flow."
I think that solution diverges. I do not get any dicergence warning. There is a serious problem. This is certain.
What is your opinion? Thx..
Kimican is offline   Reply With Quote
Old   February 6, 2016, 12:09
Michael Prinkey
mprinkey will become famous soon enough
Originally Posted by Kimican View Post
Hi guys,
Reversed flow is not (necessarily) an indication of divergence. It may however indicate that you have flow dynamics in the neighborhood of a pressure outlet. Reversed flow happens with the outlet pressure is higher than the computed pressure in the neighboring cell and the outlet starts acting like an inlet, which upsets the mass balance. You never want to have recirculation or other significant flow dynamics happening near an outlet condition. Try extending the domain at the outlet condition by adding an "exhaust pipe" and applying the pressure condition at the end of that pipe and see what happens.
mprinkey is offline   Reply With Quote
Old   February 9, 2016, 19:25
Ty for reply
I have extended the outlet and i have detected the elements where the turbulance viscosity ratio reaches the 1e5. Then i have made their quality very well.. But i could not get rid of reversed flow completely.. E.g my iterations are normal for 50 iterations then i get reversed flow for 15-20 iterations then normal then reversed flow then then then.... Is this a problem or normal? Can this situation effect my results? Ty..
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 12:23
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Outlet pressure aja1345 FLUENT 5 August 18, 2015 11:02
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 07:54
