resolution characteristics of FD schemes
Like Tree3Likes
  • 2 Post By FMDenaro
  • 1 Post By FMDenaro
Old   April 27, 2016, 13:23
Default resolution characteristics of FD schemes
Kaya Onur Dag
kaya is on a distinguished road
I am looking at 2nd and 4th order central finite difference schemes and trying to understand how good they can resolve the first derivative for each given wave number.
My routine is I make a sine curve with given wavenumber k, take the derivative with given FD scheme and transfer the result into fourier space to compare the amplitude of the corresponding wave's exact derivative.
I also check 2nd and 4th order cell centered schemes where I sample my sine curve on a finer grid with half grid spacing and get derivatives in a staggered like manner. I expect these to have better resolution characteristics, which seems true for 4th order case but not for 2nd order case. It looks exactly the same as non-staggered 2nd order FD scheme, which I can't understand. To me I just halved the grid spacing so I expect the scheme to behave twice as good in terms of wave resolution.
I am putting the figure below where x axis is wave number and y is just normalized amplitude.cc- schemes are cell-centered / staggered. My nyquist wave number is 16. I believe that I am doing something wrong but wanted to hear some opinions...
Thanks
kaya is offline   Reply With Quote
Old   April 27, 2016, 16:18
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I do not understand the figure ... you should have the transfer function starting from 1 at k=0, then it should be plotted along the dx*k variable...
for example f(x) = c(k)*exp(i*k*x) -> f'(x) = i*k* f(x) is the exact derivative.
The second order central derivative is
[f(x+dx)-f(x-dx)]/(2*dx)=
1/(2*dx)*c(k)*[exp[i*k*(x+dx)]-exp[i*k*(x-dx)]=
c(k)*exp(i*k*x) *[exp(i*k*dx) - exp(-i*k*dx)]/(2*dx)=
f(x)*i*sin(k*dx)/(dx)= i*k_eff*f(x)
you see that
k_eff/k = sin(k*dx)/(k*dx)
is =1 for k*dx = 0 and has the first zero at k*dx=pi.
I expect this kind of plot...
FMDenaro is offline   Reply With Quote
Old   April 27, 2016, 16:28
Kaya Onur Dag
but you'd expect [f(x+dx/2)-f(x-dx/2)]/(dx) to give a higher resolution than [f(x+dx)-f(x-dx)] /(2*dx) right?
I am also not sure if resolution is the right word there but thats just how I tihink about this. I'll be glad to know if there is a better fit, because I use this often when I talk with people
Thanks
Old   April 27, 2016, 16:39
[f(x+dx/2)-f(x-dx/2)]/dx=
1/(dx)*c(k)*[exp[i*k*(x+dx/2)]-exp[i*k*(x-dx/2)]=
c(k)*exp(i*k*x) *[exp(i*k*dx/2) - exp(-i*k*dx/2)]/dx=
f(x)*i*sin(k*dx/2)/(dx/2)= i*k_eff*f(x)
you see now that
k_eff/k = sin(k*dx/2)/(k*dx/2)
therefore it starts from 1 and has the first zero at k*dx/2=pi. Consider that the computational grid introduces the Nyquist frequency at k=pi/dx and you get that the formula has indeed a best spectral resolution.
davidwilcox and kaya like this.
Old   April 28, 2016, 10:59
I forgot to say that the "modified wavenumber analysis" leads to see the "spectral accuracy" of the formula. Actually, (k-keff) is nothing else but the local truncation error in the wavenumber space
Old   April 28, 2016, 11:38
Michael Prinkey
mprinkey will become famous soon enough
I can't add much to Prof Denaro's replies. I would note that you ccfd2 results are effectively working on a h-filter width while fd2 works on a 2h-filter width. The transfer function and the empirical response should reflect that. Essentially, fd2(k/2) ~= ccfd2(k). Your plot shows that for fd4(k/2) ~= ccfd4(k), but fd2(k) ~= ccfd2(k) which is clearly wrong.
mprinkey is offline   Reply With Quote
Old   April 28, 2016, 11:43
if you are interested in, I have a file with the spectral analysis of many formulas
Old   April 28, 2016, 11:53
Kaya Onur Dag
Thanks. There are many similar figures in Lele 1992, this was just my own curiosity
Thanks for all the comments.
Old   April 28, 2016, 14:30
yes, Lele showed that for some compact schemes based on Padè interpolation.
However, my warning is to consider such analysis somehow academic, in practical cases the relevance of the spectral accuracy must be analized for a non linear function.
Old   April 29, 2016, 05:59
Kaya Onur Dag
Then when you use dealiased fourier series on 2axis and a central finite difference on the other, how would you define the characteristic length scale for say smagorinsky model? Now it doesn t make much sense to me to use sqrt(dx^2+dy^2+dz^2) if you have a smaller dz for this resolution thing. The filter size you want is actaully still the length of the Nyquist wave from one of the fourier axes but dz is much smaller ( just to be able to resolve the same wave )...
or if you had dx=dz then, it would be like applying an explicit filter on z axis each yime you do a finite difference operation
Old   April 29, 2016, 07:55
if you use pseudospectral codes then it is likey you resolve non-homogeneous and non isotropic turbulence, therefore it is not correct to immagine a single lenght scale.
For example, in a channel flow the normal-to-wall direction has different characteristic lenght scales depending on the distance from wall. In performing LES, is it usual to have a DNS-like resolution along z and define a filter width only in the horizontal plane (homogeneous directions).
Old   April 29, 2016, 08:46
Kaya Onur Dag
I see, this makes sense for channel flow simulations. I am in the wind energy field and it is not possible to resolve the wall on ground-normal direction but then I can t understand how people define their length scales when they use simple smagorinsky turbulence models.. I know that there is a mismatch because smagorinsky will take energy based on isotropic turbulence yet the generated one is anisotropic and maybe talking about length scales here doesn't make much of a sense. Having said that, I want to know which length scale would be the closest to the real phsics because there is only one number that you change. (?)
Old   April 29, 2016, 08:54
Generally, the static Smagorinsky model is supplied by a damping function in wall-normal direction to take into account the anisotropy but that makes sense for a well refined grid near the wall.
I suggest to disregard the static model and use the dynamic versione in your problem
Old   April 29, 2016, 09:05
Kaya Onur Dag
Yes I looked at that log damping function that was not very active above y+ 150, in an abl simulation your first grid point is like around y+700..
I 'll change the static version to dynamic model or maybe even plane averaged model after my phd but now I just don't have enough time to implement anything more since I need to hand in something in about 6 months.
I appreciate for the comments!
Old   April 29, 2016, 10:28
For the neutral ABL, you can find useful the papers of Meneveau about the dynamic and anisotropic SGS models
kaya likes this.
Choice of numerical schemes for high accuracy in vorticity D.B OpenFOAM Running, Solving & CFD 1 February 5, 2018 10:44
Influence of schemes on mesh size, orientation and type in a convective flow field Tobi OpenFOAM Verification & Validation 8 July 16, 2017 08:01
High resolution image with parafoam Andrea_85 OpenFOAM 5 January 23, 2014 06:39
Mesh Resolution to resolve turbulent boundary layer tongx051 FLUENT 1 October 22, 2013 00:18
time stepping schemes for compressible DNS/LES shyamdsundar Main CFD Forum 0 January 14, 2010 23:15
