Fluid forces on valve disc
Old   April 28, 2016, 06:15
Default Fluid forces on valve disc
nicola_78 is on a distinguished road
Hi everybody!
I have to perform a CFD analysis on a spring-loaded valve and calculate the overall forces caused from a fluid on the valve disc.
My doubt is on how to impose my "surface goal" on the disc to find the resulting force on it and verify if it's enough to overcome spring force:
I have to impose only the side hit by the fluid flow or all disc surfaces because also pression distribuition behind the disc (greater) affects the overall force on the disc?
Thanks
nicola_78 is offline   Reply With Quote
disc, fluid, force, valve
Physics of an incompressible fluid Jonas Holdeman Main CFD Forum 87 April 22, 2019 10:40
Valve Design Flow Forces, Report moment Mans1234 FLUENT 1 August 10, 2015 17:28
tilting disc in aortic valve aidaaida CFX 3 April 22, 2015 09:50
Disc brake simulation with solids Roland R CFX 4 June 13, 2012 08:52
