Convergence problem with mesh?
Old   July 13, 2016, 17:38
Default Convergence problem with mesh?
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey All,
I am trying to solve a problem using the steady state solver simpleFoamof to simulate the flow over a C-D nozzle with a flange. I created a mesh using gmsh for y+=1, which led to a mesh spacing of 0.00008. The mesh is follows;
As can be seen, the mesh has a too many blocks. I was wondering to run this mesh using the kOmega turbulence model but unfortunately I have kept getting a divergent solution. My gut feeling tells me that the mesh might not be as expected by the solver. Even though when I did check mesh it reports that the mesh is ok, I kept getting the same issue "Divergent solution". I was wondering if some one could suggest an improvement to the mesh.
Again, thanks in advance,
Regards,
tareqkh is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 20:26
