What are the top 5 technical problems for which you are using simulation? |
August 1, 2016, 12:34 |
What are the top 5 technical problems for which you are using CFD in data center des?
Hello Everyone,
I was doing some research to identify technical problems in the data center design that can be well solved with the help of CFD. I would like to use this information for defining learning content needs in the area of data center simulation. I was wondering if you could share with me the top 5 data center problems/use cases for which you are using simulation? Thank you! Last edited by agakristo; August 2, 2016 at 03:25. |
Data Center Simulation | scottg | Main CFD Forum | 8 | February 11, 2024 06:17 |
Problems with an overexpanded nozzle simulation | nmtr | FLUENT | 0 | April 11, 2015 07:01 |
problems of turbo simulation in CFX-10 | Qiang | CFX | 0 | September 11, 2006 23:19 |
Biphasic simulation (GVF 80%) - Overflow problems | Robbe | CFX | 0 | February 21, 2006 10:22 |
Technical Problems at CFD Online | Jonas Larsson | Main CFD Forum | 0 | May 6, 2005 13:35 |
