September 27, 2016, 01:01 |
Boundary conditions for compressed air
raunak jung pandey
Rep Power: 9 |
I am trying to run a simulation using compressed air. Compressed air is fed to the inlet with maximum pressure 15 Bar. The supply rate is controlled by air flow controller allowing mass flow up to 25 g/s. and the outlet is into atmospheric condition.
How do I setup my boundary conditions for the experiment ? Which system is more robust - pressure inlet condition or mass flow rate condition ? Do I need to change the density of air at the inlet conditions ? Please help me in understanding the problem. Thank You |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
