Tesla Turbine
Old   September 28, 2016, 15:12
Default Tesla Turbine
Saima
Saima is an unknown quantity at this point
I have a CFD problem of co-rotating discs (a simplified tesla turbine). Fluid is CO2, with 3MPa pressure and 10,000 rpm.
What are the boundary conditions need to be taken?
As per my understanding its a compressible flow, wanna make sure is it correct?
Total pressure and temperature will be inlet boundary conditions and outlet static pressure.
Kindly give me suggestions.
Best Redards,
Saima
Saima is offline   Reply With Quote
Old   September 29, 2016, 15:52
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
Hello Saima,
this sounds quiete interesting. As the inlet total pressure is most probably significantly higher than the outlet pressure the fluid should assumed to be compressible.
Which turbulence model are you going to use for this? I am sure you are aware of the fact, that you need a high quality boundary layer mesh for this, as boundary layer effects are the basis principle of a tesla turbine.
Secondly, how exactly do you model the discs? Do they have a certain roughness? As far as I know the discs in a tesla turbine are very close to each other. A certain roughness or a no-slip condition will probably have very different effects on the flow field.
DarylMusashi is offline   Reply With Quote
Old   October 18, 2016, 20:18
Saima
If need to define dimensionless mass flow rate at inlet, what is the possibility to do that?
Originally Posted by DarylMusashi View Post
Hello Saima,
Best Redards,
Saima
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
6dof for rotation of turbine: unable to fix the center Havinh Fluent UDF and Scheme Programming 0 August 5, 2015 05:35
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
Rigid Body Motion Setup for Tesla Turbine me3840 FLUENT 0 October 26, 2011 17:54
Tesla Turbine analysis in CFX sivarama1 CFX 2 September 5, 2009 20:37
