flow in gas turbine
Old   September 14, 1998, 08:22
Default flow in gas turbine
Abdul Hafid
I am doing my theses in simulation of flow in gas turbine (the flow between the blades ), and I am looking for experimental data of the flow in the turbine. Could any body point to me the direction where can I find that?
Old   September 14, 1998, 09:39
Default Re: flow in gas turbine
Jonas Larsson
There are a number of well documented test cases for the ERCOFTAC workshop on Turbomachinery Flow Predictions - See the announcement made in this forum a week or so ago, it also includes a link to their web page I think. The advantage with using these test cases is that you have the opportunity to meet with other colleagues working on the same cases and compare results and exchange ideas.
They also publish some kind of report from the workshop each year, so even if you don't attend the workshop you can read about problems etc. that other groups had with the different cases.
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
Gas flow in vortex tube - LES and grid resolution bernarde Main CFD Forum 1 March 26, 2009 10:50
Re: how to do this turbine blade passage flow nanl manish Siemens 0 January 12, 2006 11:37
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 16:53
