low speed compressible flow
Old   October 27, 2016, 07:08
Default low speed compressible flow
Abolfazl
Abolfazl_cfd is on a distinguished road
Hi everyone.
I am trying to simulate compressible viscous flow around a circular cylinder by implementing VAN-LEER scheme.
for supersonic flow the results are satisfactory but for low mach number (mach=0.3 and Reynolds=300) I can't simulate the vortex shedding. I only get two stationary small vortexes.
can anybody suggest me what should I do!??
thanks.
Abolfazl_cfd is offline   Reply With Quote
Old   October 27, 2016, 07:24
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Abolfazl_cfd View Post
Hi everyone.
thanks.
two steady symmetrical vortical structures indicate that you are resolving an actual low Reynolds number.... Try a grid refinement study.
FMDenaro is offline   Reply With Quote
Old   October 27, 2016, 08:22
Abolfazl
thank u for your reply.
but my mesh is fine enough. the problem is as i increase the mach number the length of steady symmetrical vortexes increase and as i decrease the mach the length decrease.
I don't think this is related to mesh.
Old   October 27, 2016, 08:26
Assuming the speed of sound is the same, you are changing both the Mach and the Reynolds number. If you decrease it and your scheme has numerical viscosity, your actual Re number can be as low as to produce a laminar steady solution. Ensure that at low Re you have no turbulence model active in your code.
Old   October 27, 2016, 08:35
Abolfazl
thanks again. but the code is non-dimensionalized and I just set reynolds and mach number separately. so the speed of sound may not be constant at different mach numbers.
my numerical method is Van-Leer and it is first order upwind. and i don't have turbulence model.
Old   October 27, 2016, 08:51
the solution with first order upwind is full of artificial viscosity...check your grid is so fine to get the cell Reynolds number =O(1) everywhere
Old   October 27, 2016, 09:24
Abolfazl
thanks again.
I have checked with really fine grid and I'm almost certain the grid is fine enough.
but don't you think that Van Leer doesn't work properly for low mach numbers or for viscous flows!?
Old   October 27, 2016, 17:29
Martin Hegedus
Martin Hegedus is on a distinguished road
Can't say if Van Leer will work or not, but, since your original post reads as if you may have written the code, did you divide the Reynolds number by the Mach number? For a non-dimensionalized compressible solver the Reynolds number is, in general, calculated using the speed of sound rather than the velocity therefore the inputed Reynolds number (which in general is calculated using velocity) is divided by the Mach number internal to the code.
Martin Hegedus is offline   Reply With Quote
Old   October 30, 2016, 04:18
Abolfazl
Dear Martin.
Thank u for your reply.
No, I didn't divide the Reynolds number with Mach number. I just set Mach and Reynolds number. and the Reynolds number is base on free stream velocity.
Old   October 30, 2016, 09:47
Martin Hegedus
Given your reply, I'm not sure my post was understood correctly. In general, the Reynolds number that goes into compressible solvers is based on the freestream velocity. So your post reads as if your input is correct. However, internal to a compressible code the Reynolds number will be modified to be based on the speed of sound by dividing by the Mach number. So, if you have written your own code, make sure your equations are non-dimensionalized consistently.
how to set BC for compressible flow target mass flow rate foolboy007 FLUENT 1 April 4, 2012 03:24
Can OpenFOAM generate flow at the speed of light? Michel_sharp OpenFOAM 6 October 24, 2009 04:09
How to set Boundary in comepute low speed flow zuo FLUENT 3 June 4, 2009 16:44
Low Reynolds, compressible flow andre burdet Main CFD Forum 0 February 21, 2001 11:13
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
