November 23, 2016, 23:56 |
Pressure Dirichlet value in BiCG STAB
Jawahar
Rep Power: 9 |
I am solving the pressure poisson equation in BiCG STAB, I am using finite element formulation. the matrix is like this AX=B. Where A is the matrix where each row represents the weight of the surrounding nodes of that node considered(can be taken as the center node which is unknown). X is the unknown node phi and the corresponding B is the known value of the grad times the provisional velocity.
Suppose if there are 9 nodes in 2D, the nodes be numbered from 1 to 9, let 9th node be the center of all other nodes, then the matrix A the row will look like, [weight of node1 weight of node2 .. .. .. .. .. .. .. weight of node 8] the X will be [phi of 9] and B will be [grad times velocity] The problem is when we consider the pressure nodes with known values(i.e., Dirichlet nodes) , then i remove the weight of the nodes from A and add that to B with the given dirichlet values multiplied with the weights of that nodes. This makes the solution to diverge when i give any values other than zero(dirichlet), Can anyone help me how to give this constant dirichlet value in the matrix?? |
November 24, 2016, 03:41 |
Filippo Maria Denaro
Rep Power: 71 |
Are you using a library or is your own-made solver?
November 24, 2016, 03:46 |
Jawahar
Rep Power: 9 |
November 24, 2016, 03:53 |
Rep Power: 71 |
Check if your solver converges with a source term such that the solution is constant, for example 1
dirichlet pressure, finite element method, iterative pressure solver, poisson equation |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Outlet pressure | aja1345 | FLUENT | 5 | August 18, 2015 11:02 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
