Oscillating behaviour of variables in a very fine grid |
May 4, 2017, 10:56 |
Rep Power: 11 |
Hi guys,
i'm simulating the flow around an airfoil of a turbine and had to do a grid convergence study. Therefore i refine my mesh in TRACE, by multiplying the number of nodes in i,j,k-direction by two (finer mesh), and three (finest mesh). So the first mesh has about 2.1 million nodes, the second 16.3 million and the finest about 54.4 million nodes. When i look at the distribution of the Cp-Value on the blade surface, the finest mesh shows an oscillating behaviour (Screenshot). And so all the other calculated variables, like density. TRACE uses linear interpolation to set the new points. But the oscillating behaviour can't be seen in the results of the first two mesh, so i think that's not the problem. Maybe it is a numerical problem? Anyone with ideas? Thanks in advance and sorry for my bad english. Greetings, Stuntmanbob |
May 4, 2017, 11:04 |
Filippo Maria Denaro
Rep Power: 71 |
Are you working in double precision? check if the grid refinement over the airfoil is smooth
May 4, 2017, 12:40 |
Rep Power: 11 |
you're right, the smoothness looks very bad. Thank you very much Greetings, Stuntmanbob |
Residuals show oscillating behaviour ! | anon_l | STAR-CCM+ | 1 | October 30, 2016 14:38 |
Grid Check Script | pdp.aero | SU2 | 2 | April 23, 2015 01:54 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 11:18 |
Algebraic Multigrid for nonuniform grid | Joshua Lee | Main CFD Forum | 4 | March 16, 2000 13:05 |
Non-uniform grid calculation | Aspens | Main CFD Forum | 1 | February 23, 2000 14:15 |
