Highest lift coefficient
Like Tree1Likes
  • 1 Post By Johan Schulten
Old   February 29, 2000, 02:26
Default Highest lift coefficient
Mark Render
I'm am looking for an airfoil shape (without flaps etc.) with a very high max. lift coefficient. Obviously the ratio of lift to drag coefficient should be high as well in that point. Is there an 'ultimative' airfoil shape ?
Mark
Old   February 29, 2000, 03:09
Default Re: Highest lift coefficient
Johan Schulten
Hello Mark, Yes, there exists such a thing and it is called a Liebeck airfoil after its originator. The most complete reference I know is AIAA Paper 76-406 "On the Design of Subsonic Airfoils for High Lift" by Robert H. Liebeck. You can also look in "High-Lift Aerodynamics" by A.M.O. Smith, Journal Of Aircraft, Vol.12, No.6, June 1975, pp.501-530 or: "A Class of Airfoils Designed for High Lift in Incompressible Flow" by Robert H. Liebeck, Journal of Aircraft, Vol.10, No.10, Oct. 1973, pp.610-617. The theoretical maximum Cl for a single element airfoil at a Reynolds number of 5x10^6 is 3.06 with a lift to drag ratio of 600!
kcengiz likes this.
Old   March 2, 2000, 01:38
low
Read the articles introduced from Johan. For highest lift, from my experience, one should modify the shape of an original airfoil such as introduce stepwise discontinuity on the airfoil.
Old   March 2, 2000, 03:39
Mark Render
Could you explain in more detail what you mean by that ?
Mark
Old   March 2, 2000, 08:02
Tim Franke
Hi Johan,
haven't read these papers I guess that this airfoil is not symmetric. Do you know a high lift single element airfoil that is symmetric ?
Thanks in advance,
Tim
Old   March 2, 2000, 08:30
Johan Schulten
Hello Tim,
Yes, the Liebeck airfoils are highly cambered to achieve high lift at low drag. To me it seems rather contradictory to speak of a symmetric high lift airfoil. If I may rephrase your question to: "What would be the highest lift for a symmetric airfoil?", I can refer you to the Resources\References\Airfoils of this Website. A maximum Cl of 1.6 [NACA 0012] is typical for symmetric airfoils of moderate thickness.
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 11:48
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
Help needed - lift coefficient on front/rear axle Jan Jagrik FLUENT 0 September 21, 2000 10:21
