System Comparison proof transient <-> steady state |
May 24, 2017, 01:15 |
Rep Power: 8 |
I have two similar systems I. and II. I. is steady state and defined by these variables: - Distance A - Distance B - Volume flow C The resulting variable I am studying is T. II. is transient and defined by these variables: - Distance A - Distance B - Frequency f - Pressure P The resulting variable I am studying is T. The literature I have read hints to the conclusion that II. may be expressed as I., which would save me a lot of computation time. At the moment I am stuck with the following problem: How can I proof, that II. can be expressed as a modification of I. and how can I derive a set of equations, which describe the necessary modifications? e.g.: I thought about conducting DoE studies for I. and II. and using response surface methodology to find correlations. But I do not know if this would be either possible, or scientifically sound. Any advice or ideas? kind regards, Mabubel |
Steady state solution as an initial condition for a transient problem | adnanakhtar | FLUENT | 7 | November 25, 2016 05:16 |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
