Opening of new module in Salome crashes
Old   May 26, 2017, 11:58
Default Opening of new module in Salome crashes
Abhijit
vegaonline is on a distinguished road
Dear Experts,
I wish to run Salome 8.2 on OpenSuse Leap 42.2 64 bit. The laptop has i915 graphics card and Nvidia card. I am using Nvidia-bumblebee with bbswitch so that normally NVIDIA is switched off and I use "optirun" to switch on NVIDIA and run CUDA commands.
As I run salome I see that Salome main window appears without error. Now as I clock new to open geometry or mesh module, I see following error
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  153 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  28
  Current serial number in output stream:  29
vega@jupiter:~> Terminating SALOME on port 2810...
vega@jupiter:~>
and the software crashes.
I request experts to help me to resolve the issue. By the by, I can run paraFoam etc. from docker based OpenFoam installation.
Thanks and Regards
vegaonline is offline   Reply With Quote
gpu, nvidia, salome
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 18:00
[foam-extend.org] Module file foam-extend 3.2 CentOS cluster KarthickRajkumar OpenFOAM Installation 2 March 26, 2017 13:52
checkMesh and decomposePar crashes with salome IDEAS mesh pajofego OpenFOAM 0 June 23, 2011 08:43
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
Lamboot trouble r2d2 OpenFOAM Installation 4 October 17, 2005 04:27
