June 6, 2017, 05:12 |
Turbulence initialization!!!
Akanksha Rawat
Rep Power: 12 |
What is turbulence initialization only? How is it different from the turbulence applied for the whole simulating time? I tried to compare the results with laminar and I found them exact! Then what is the use of this initialization only?
Thanks |
June 6, 2017, 06:47 |
D. N. Venturi
Rep Power: 13 |
The numerical methods need an initial guess, either transient or stationary. That's why you need initialization values for the turbulence.
June 6, 2017, 07:00 |
Quang Le Dang
Rep Power: 14 |
If you use FLUENT, hybrid scheme for initialization is the best way. If you don't have information and cannot use hybrid, use value from inlet. This is just a "guess" for numerical solution
how to set URANS turbulence model in unsteady flow simulation | TimLiu | OpenFOAM Pre-Processing | 0 | April 25, 2017 08:52 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Turbulence length scale | Leonpolou | FLUENT | 2 | January 23, 2013 07:26 |
Diverging Turbulence | nickninevah | STAR-CCM+ | 3 | May 28, 2011 12:44 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
