Most common Turbulence models for shallow flows (2d) |
June 24, 2017, 18:12 |
Rep Power: 8 |
Can you give me a short and brief explanation of the pros and contras of the most used models for shallow water flows? And if possible, some references, please?
I've been looking for some time now but I have not found something clear enough to me, as I'm new in this field. |
June 26, 2017, 17:01 |
Paul
Rep Power: 9 |
The main thing you have to worry about with shallow water flow would be how the boundary layer affects the object of interest.
k-omega SST is usually the "go-to" since it includes the positive aspects of the k-epsilon as well as including good near wall treatment. Realizable k-epsilon used to be the go-to, but it requires higher mesh refinement near the wall. You can find the CFD-Online page on turbulence modeling below [1]. As a general statement, you can probably stick with k-omega SST while you're getting familiar with CFD. As you get more experience, you'll understand the models more. [1] https://www.cfd-online.com/Wiki/Turbulence_modeling |
June 26, 2017, 22:46 |
I though that those wall issues were not present in 2D flows
#3 | |
Rep Power: 8 |
June 27, 2017, 10:03 |
Paul
Rep Power: 9 |
Jaydi_21,
Well as with everything in CFD it depends on your boundary conditions. k-omega SST will work well with most cases. I don't see any reason why it wouldn't work for your case. Walls are boundaries where a no-slip condition is applied. This means that the velocity on the wall is zero. With k-epsilon, layers of mesh (called prism layers or inflation layers) were needed to capture the gradient between the wall and the bulk flow. With k-omega SST, a blending function is used to model this gradient--hence less mesh refinement near the wall is needed. I don't know the boundary conditions for your case, however I would recommend sticking with k-omega SST for now. Like I said, you'll understand more about turbulence modeling as you get more experience with CFD. |
large eddy simulation., shallow flows, shallow water equations, turbulence, two dimensional model |
y+ range for turbulence models | babri | FLUENT | 1 | August 30, 2016 17:39 |
Advice about turbulence models? | mqsim | OpenFOAM Running, Solving & CFD | 6 | April 27, 2016 07:50 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 10:35 |
Two-fluid models vs mixture models for bubbly flows | Hansong Tang | Main CFD Forum | 6 | December 8, 2009 03:21 |
turbulence models for strongly separated flows | peter schaffarczyk | Main CFD Forum | 3 | February 9, 1999 17:49 |
