second-order discretization of viscous stress tensor |
August 30, 2017, 12:11 |
Selig
Rep Power: 10 |
I am discretizing the viscous stress tensor using FDM (as I am going to be performing RANS modelling) and was curious if my formulation is correct.
August 30, 2017, 12:18 |
Filippo Maria Denaro
Rep Power: 71 |
First, the stress tensor has onlt first order derivatives, the outer you wrote is the divergence that applies on the stress component.
Then, it is difficult to see the discretization without a figure of the collocation of the velocity components. Did you already extracted out the isotropic part of the tensor S? |
August 30, 2017, 12:32 |
Discretization
Selig
Rep Power: 10 |
The viscous stress tensor I am working with attached. In terms of the velocity-pressure arrangement, I am working on a collocated grid. I will upload a figure of my stencil. By the way, this is for incompressible Navier-Stokes.
August 30, 2017, 12:51 |
Rep Power: 71 |
If you extract out the isotropic part of the modelled stress tensor, it is included in a modified pressure term that you solve directly by the Poisson equation enforcing the divergence-free constraint.
Therefore, you work with Div (mu_t *Grad0 v_bar), being now the tensor tau_xy at zero trace. Now, assuming you have u,v and mu_t on the same nodes, you start with d (tau_xy)/dy -> (mu_t(i,j+1/2)*tau_xy(i,j+1/2)-mu_t(i,j-1/2)*tau_xy(i,j-1/2))/dy you can use a linear reconstruction for mu_t: mu_t(i,j+1/2)=0.5*(mu_t(i,j+1)+mu_t(i,j)) mu_t(i,j-1/2)=0.5*(mu_t(i,j)+mu_t(i,j-1)) and, accordingly, you discretize the tensor tau_xy and so on |
August 30, 2017, 13:33 |
Discretization
Selig
Rep Power: 10 |
August 30, 2017, 19:16 |
Rep Power: 71 |
be careful, the derivative dv/dx cannot computed without the averaging between two derivatives. For example
dv/dx|j+1/2 = 0.5*(dv/dx|j+1 + dv/dx|j) dv/dx|j-1/2 = 0.5*(dv/dx|j-1 + dv/dx|j) |
August 31, 2017, 10:36 |
Viscous stress tensor
Selig
Rep Power: 10 |
August 31, 2017, 11:51 |
Rep Power: 71 |
why are you evaluating dv/dx at half node instead of using i,j+1/2 and i,j-1/2 as for du/dy?
However, I suggest to work in a different manner much more similar to the FV formulation. Define the flux_ovest(i,j), flux_sud(i,j) matrices (for 2d, in 3D you need a further matrix). Use the staggered notation, for example flux_ovest(i,j) is at the face i-1/2,j and flux_s(i,j) is at i,j-1/2. The compute all the flux once over all the half nodes. Finally simply sum the fluxes according to flux_ovest(i+1,j)-flux_ovest(i,j) flux_sud(i,j+1)-flux_sud(i,j) |
August 31, 2017, 12:22 |
#9 |
Selig
Rep Power: 10 |
I looked in Ferziger's book on FVM and found something related to discretizing tau_xy. Despite his assumption on constant mu, could I adopt this discretization procedure? I realize that since my viscosity is not constant I will have to interpolate accordingly. Given he is working in a FVM formulation I would have (tau_yx)_east - (tau_yx)_west
EDIT: To be more specific I am currently trying Therefore we have |
August 31, 2017, 12:47 |
#10 |
Rep Power: 71 |
But Eq.(7.90) is presented for a staggered arrangement while you are using a colocated one. Compute only either tau_xy_est or tau_xy_west an memorize the value in a matrix. Owing to the conservative properties you need nothing else to do the update. |
August 31, 2017, 13:30 |
#11 | |
Selig
Rep Power: 10 |
You are 100% right, I was too hasty and overlooked that.
In terms of a conservation law, when taking the flux face it is composed of half points. Thank you for your patience... Last edited by selig5576; August 31, 2017 at 15:12. |
August 31, 2017, 14:35 |
#12 |
Rep Power: 71 |
yes, just correct the dv/dx derivative and the discrete formula is right... remember that you do not need to compute twice the same term on a face
August 31, 2017, 15:16 |
#13 |
Selig
Rep Power: 10 |
August 31, 2017, 15:45 |
#14 |
Rep Power: 71 |
I don't agree, in my mind I have this discretization
dv/dx|i,j+1/2 => 0.25*(v(i+1,j+1)-v(i-1,j+1)+v(i+1,j)-v(i-1,j))/h |
calculating the viscous stress tensor tau for viscous dissipation heating | dgadensg | OpenFOAM Programming & Development | 5 | January 17, 2023 15:20 |
post-processing utility R, calculating Reynolds stress tensor | volker | OpenFOAM Post-Processing | 17 | May 21, 2020 17:36 |
Reynolds Stress Tensor | Sergio13 | OpenFOAM Post-Processing | 12 | May 11, 2020 05:40 |
Convergence of Reynolds Stress Tensor / Fluctuations in OpenFOAM | Anne Lincke | OpenFOAM Running, Solving & CFD | 0 | July 17, 2012 10:50 |
Higher order discretization on staggered grid | Chandra Shekhar | Main CFD Forum | 9 | January 27, 2005 16:31 |
