Oscillating temperature in DPM heat transfer
Old   September 5, 2017, 02:07
Default Oscillating temperature in DPM heat transfer
James Huang
JamesQ is on a distinguished road
Hi guys
I am running a really simple case to examine the heat transfer between nanoparticles (alumina) and the base fluid (water). In particular, I'm examining the conduction between particles and fluid and simplified the model by putting only one particle (40nm) in a 120nm*120nm*120nm domain. The particle is set 298.15 K and water set to 598.5 K to achieve an equilibrium of 301.5 K. But the model just doesn't settle and the temperature goes up and down from a few hundred K to almost 5000 K. The attached are the screenshots of the residual and warnings about temperature limits. All boundaries are adiabatic and no heat source in the domain.
P.S. The model works when the water temperature is set to 465 K (for an equilibrium of 300K)
Any help would be appreciated!
Sincerely
James
JamesQ is offline   Reply With Quote
dpm fluent, heat transfer
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Convection heat transfer with unknow stream temperature moienfar-CFD FLUENT 3 February 22, 2013 10:49
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
