Need Fortran code
Old   October 12, 2017, 01:49
Default Need Fortran code
bob
batuning is on a distinguished road
Dear friends ,
i need a code about (Airfoil NACA 5 digit ) for FORTRAN ,to make an airfoil
also need graphic airfoil
i have equations ,please someone help me .m new for FORTRAN
thanks
batuning is offline   Reply With Quote
Old   October 13, 2017, 01:07
Lane Carasik
lcarasik is on a distinguished road
Originally Posted by batuning View Post
Dear friends ,
thanks
Are you asking for help to write the FORTRAN code? If so, where are you having trouble?
lcarasik is offline   Reply With Quote
Old   October 13, 2017, 03:46
bob
yes .true
i have problem with equation .
how i should add the equation's to FORTRAN
the equation of curve line of airfoil is :
Yc= m/p**2(2px-x**2) ===================== from x=0 to x = p
Yc= m/(1-p)**2[(1-2p)+2px-x**2] ============ from x=p to x= c
Equation for calculate thickness upper and down the middle line of airfoil :
+ Yt = t/0.2(0.2969 RADICAL x - 0.1260 x - 0.3516 x**2 + 0.2843 x**3 - 0.1015 x**4)
the Equation of final dimensions of upper surface and down surface of airfoil :
Xu=x-Yt * SIN TETA
Yu=Yc+Yt * COS TETA
Xl=x+Xt * SIN TETA
Yl=Yc-Yt * COS TETA
Where TETA = ARCTAN[dYc/dx]
x= chord length
y= vertical length
t= MAX thickness
m= MAX curve
p=MAX leading edge curve
Old   October 13, 2017, 04:23
bob
I have a example code but this code is for NACA 4 digit .i need NACA 5 digit also i need the Graphic picture of Airfoil :
i just want Design an Airfoil ..not flow making or analyze . simple 5 digit airfoil design also have graphic form
http://people.sc.fsu.edu/~jburkardt/f_src/naca/naca.f90
Old   October 14, 2017, 13:58
Lane Carasik
Without digging in deeper into the code, it looks like the framework is there for you to just change the equations. I'm not sure what your issue is specifically. Are you having trouble setting up the equations in Fortan? Do you have experience using fortran before?
Old   October 14, 2017, 14:26
bob
Thanks
i don't have any experience for FORTRAN before im totally new in this
if you can make it simple for me .that i can understand and put my numbers to the code ,
that i exactly want is :
only make a 5 digit airfoil and have graphic form of this ( maybe with tecplot or something ... )
i don't need airflow equations ..or any extra thing ...only a design simple airfoil form just it .
i also have another better code .but i dont know how to send here
Old   October 14, 2017, 14:40
bob
naca.zip
also another one
airfoil platform.zip
Old   October 14, 2017, 14:42
Lane Carasik
Thanks
You should spend some time and learn the basics of the coding in FORTRAN if you want to modify it for your purposes.
Old   October 14, 2017, 14:47
bob
yes exactly
thanks i will do it ,
and if you find something to help me ..please don't hesitate
airfoil 2d, fortran 90, fortran code, fortran compiler
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 11:03
CGNS fortran code compiling with intel visual fortran xe dokeun Main CFD Forum 1 April 5, 2012 21:01
Discontinuous Galerkin schemes -- fortran source code diedro Main CFD Forum 3 March 12, 2011 10:20
Who can find me this fortran code 'CHEMR'? Dong Ye Main CFD Forum 1 October 13, 2005 17:02
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
