Derivation of momentum equation for newtonian fluid in cylindrical coordinates |
December 11, 2017, 09:03 |
Robin Kamenicky
Rep Power: 11 |
Hi everybody,
Would anyone have some tip for source, where would be complete derivation of momentum equation for newtonian fluid in cylindrical coordinates? Thank you, Rob |
December 11, 2017, 11:21 |
Filippo Maria Denaro
Rep Power: 71 |
Many basic fluid dynamic textbooks illustrate the NS equation in cylindrical coordinates, do you need only the expression or do you want to understand how the expression is derived from the general vector formulation?
December 12, 2017, 08:01 |
Robin Kamenicky
Rep Power: 11 |
Hi FMDenaro,
First of all, thank you for the reply. I would like the entire derivation of differential form from scratch. I would like to see wether the area of the finite element faces are different. I saw different approaches to this. In one source, the faces in r direction were computed r*dangle*dz and (r+dr)*dangle*dz and in another one they assumed to have same areas. Sure, smaller the element, the more similar areas. Also the derivation of viscous stress components would be interesting to see. I checked following document where in r direction, the normal stress in the angle direction is added. I do not understand the reason for it. Overall, I feel I quite understand the derivation but there are some small nuances in which I am not 100% sure. So I would appreciate a source as detailed as possible. |
December 12, 2017, 11:39 |
Rep Power: 71 |
You can find some explanations but they are quite equivalent each other.
I generally introduce to my student the general vector notation for the expressing the equation (valid for any type of reference system) and them express the components of the vectors and differential operators in the chosen reference system. For example: v= ir *vr+ itheta *vtheta+iz*vz and the differential operator nabla = ir *d/dr+ itheta *(1/r)*d/dtheta+iz*d/dz (see https://en.wikipedia.org/wiki/Del_in...al_coordinates) so that for example the divergence of the velocity is (ir *d/dr+ itheta *(1/r)*d/dtheta+iz*d/dz).(ir *vr+ itheta *vtheta+iz*vz) and now you have to extend the expression using the rules for the products and derivatives. The same procedure is applied for the gradient of both a scalar and vector function. |
conservation of momentum, cylindrical coordinates, newtonian fluid, theory |
Finite Volume Method For Cylindrical Coordinates | falopsy | Main CFD Forum | 45 | August 14, 2023 21:14 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Derivation of Momentum Equation | jbambery | Main CFD Forum | 1 | June 9, 2006 13:27 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
