February 7, 2018, 02:03 |
Total pressure drop & static pressure drop
hello everyone.. i have a doubt about total and static pressure drops.here is my questions.
1.consider a pipe which having small bend, for that if i measured total pressure drop will give idea about how energy get loss by fluid flow. so we can think about modification on bend or something. but measuring static pressure drop at inlet and outlet is for what purpose? 2. if flow is get recirculated at the bend,then what about the overall total & static pressure drop of the pipe? they will increase or decrease? |
April 11, 2018, 02:15 |
#2 | ||
JD
Rep Power: 9 |
April 11, 2018, 03:07 |
#3 | |
So For a pipe or bend which have same inlet and outlet diameters, static and total pressure drops should return same value. I would recommend always go by total pressure drop to compare the energy lost in due to pipe friction or bend or anything else. Last edited by ashokac7; April 11, 2018 at 04:42. |
April 11, 2018, 03:32 |
Filippo Maria Denaro
Rep Power: 71 |
Any time that dissipative effects take a role, the total pressure diminuishes as it indicates the total kinetic energy that can be obtained. Dissipation degrades the potential level of kinetic energy as internal energy takes more relevance.
pressure drop |
Case of fixed inlet total pressure and fixed outlet static pressure | Sunxing | OpenFOAM | 8 | September 9, 2019 05:56 |
Excessive static pressure drop in elbow flow | Teles | CFD Freelancers | 4 | June 4, 2017 17:11 |
Difference between total pressure, total pressure in Stn and in Rel frames | turbo5 | CFX | 6 | January 21, 2016 16:05 |
total pressure and pressure drop | omaralyahia | CFX | 5 | July 14, 2015 08:13 |
Static vs Total Pressure | Alfonso Ferrandez | FLUENT | 2 | May 23, 2000 08:53 |
