February 9, 2018, 04:34 |
Selecting turbulence model
A. Min
Rep Power: 12 |
Hi all
I want to solve this problem: 3D incompressible flow of air around the axis of a cylinder in Ma=0.2. 1-which turbulence model (or models) is better? what is in priority? 2- could you plz help me for chosing appropriate boundary conditios? ecpecially for pressure. because this problem is in p_inf = 30 kPa. should I set the up, down, outlet, front and back in 30 kPa? or that is not important and it can be every value? In a tutorial in openFoam that is for a 3D airFoail I saw that they set freestreamPressure! what is that? Also they set inlet and outlet (the right hand side of my geo in pic) velosity the same! why? should I set them the same for my problem? I think that is wrong and I must allow the code to calculate it! 3- Is it correct to do it with simpleFoam for turbulent and icoFoam for laminar regim in openFoam? http://uupload.ir/files/gez0_untitled.png Thank you so much |
February 17, 2018, 11:23 |
selection of Turbulence model
Syed Waqar Mehdi
Rep Power: 10 |
Hello
I am currently doing a project regarding analysis on airfoil of Vertical axis wind turbine , I have already researched about many turbulence models like realizable K-epsilon , RNG K-Epsilon, spalart allmaras and K-Omega SST but which should i select and on what basis. Please help me about this |
February 17, 2018, 11:42 |
#3 | |
Victor Casquero
Rep Power: 8 |
February 17, 2018, 13:18 |
Syed Waqar Mehdi
Rep Power: 10 |
Yes! i am really confused but i think i need precison in pressure gradient but what i need is the pros and cons of these so that it becomes convinient for selection.
February 17, 2018, 14:12 |
#5 | |
Victor Casquero
Rep Power: 8 |
openfoam, turbulence |
NEW turbulence TRANSITIONAL model | giammy92 | OpenFOAM | 3 | June 30, 2016 09:47 |
selecting turbulence model and its boundary | BakedAlmonds | OpenFOAM Pre-Processing | 0 | June 22, 2016 07:13 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
Help Selecting Turbulence Model for VOF Problem | NavierIsStoked | FLUENT | 0 | November 1, 2013 11:27 |
