Tandem Blade investigations using Mises
Old   March 22, 2018, 13:08
Default Tandem Blade investigations using Mises
Legin Benjamin
Legin is on a distinguished road
Hello fellow members,
I am trying to run simulations on tandem blades in Mises. I managed to get a decent grid from iset, but I am facing some troubles with while running ises. In short I would like to know the right combination of global variables and constraints for tandem blades (subsonic).
I initially tried with (screenshot for list of global variables and constraints attached) :
Variables: 1(inlet flow slope) 2(grid exit slope) 5(LEstagnation point) 15(Ma1)
constraints: 1(drive inlet slope to Sinl) 4(trailing 15(drive Ma1 to Minl)
This combination worked well for single element blade analysis. However it does not run for tandem blades. Precisely the error is "Convergence failed at...", "MIXOUT C-cell segment not found"
Please find the attached image for the ises file used. I tried out some other combinations of global variables and constraints as well:
'1 2 15 6
1 4 18 6' (this is similar to that used in the default tandem test cases provided by Mises:"arl2")
'1 2 5 15 6
1 3 4 18 6'
'1 2 15 16
1 4 15'
And a few others, but none worked out. Also the tandem subsonic test case provided by Mises("arl2") does not converge either and displays the same error mentioned above.
I hope that there are experienced Mises users in this forum who could help me out.
With best Regards
Legin
Legin is offline   Reply With Quote
[BladeModeler] How to set the shroud diameter in Blade Generator Stabum ANSYS Meshing & Geometry 1 January 17, 2018 14:22
[TurboGrid] Slotted rotor Blade using Turbogrid drcsm ANSYS Meshing & Geometry 0 March 15, 2016 00:26
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
Compressor Blade Analysis in Ansys CFX LynchMobster47 Main CFD Forum 0 April 10, 2012 22:43
Tandem Blade A.S. Main CFD Forum 0 April 18, 2005 10:11
