Thrust calculation from cfd data(Numerical Integration)
Old   April 23, 2018, 06:18
Default Thrust calculation from cfd data(Numerical Integration)
Bal Krishan
balkrishan is on a distinguished road
I am doing CFD analysis on the supersonic nozzle, I need to calculate the thrust of the nozzle from CFD data. I don't know how to calculate the thrust numerically. The equation for thrust calculation is
T = \int \rho u (u.n) dA
please help
balkrishan is offline   Reply With Quote
Old   April 23, 2018, 11:57
AliE is on a distinguished road
If you use a particular software, maybe you have the integration option somewhere in the post processor. However, in order to evaluate that surface integral numerically, you consider constant the integrand over each cell face composing the patch where you need to evalute the momentum fluxes. Doing this your integral will be: \sum_{1}^{N} mf*Uf*Af, where Uf is the face center value for the velocity, Af the face area while mf is the mass flow rate throught the patch.The sum extends to all the patch faces. Hope this help.
AliE is offline   Reply With Quote
Old   April 23, 2018, 13:34
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Numerical integration is simple, because it can be reduced to a summation (as Ali mentioned). The problem here is to define a appropriate surface for the integral. If it encompass a too large volume, some of the thrust is transformed in heat (via turbulence) and your value gets too low.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 23, 2018, 15:03
steve_podleski is on a distinguished road
take the gage pressure at the nozzle interior surface and element area normal to thrust direction and add the momentum of the flow of the upstream boundary of the nozzle. (the viscous forces on parallel surface may be insignificant....depends on the level of accuracy that your require).
steve_podleski is offline   Reply With Quote
Old   April 24, 2018, 05:45
Bal Krishan
thanks for suggestions I will look and get back if some problem comes.
Torque Calculation in CFD Kamilva Main CFD Forum 6 June 23, 2016 12:34
[ICEM] y-plus calculation & transmission into icem cfd smaru ANSYS Meshing & Geometry 1 May 9, 2016 02:56
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 8, 1998 08:19
ASME CFD Symposium - Call for Papers Chris R. Kleijn Main CFD Forum 0 September 3, 1998 08:45
Gradient calculation in CFD apurva shukla Main CFD Forum 1 August 21, 1998 07:05
