Adding wall thickness to an artery stl file
Old   July 8, 2018, 09:24
Default Adding wall thickness to an artery stl file
Sangeet
sangeet is on a distinguished road
I am involved in an FSI case in foam-extend 4.0 (fsiFoam solver). I have an STL file which represents the fluid region inside an artery. What I need is also the solid region. I have tried adding thickness with Blender but some deformities arise in the mesh.
Could anyone recommend some ways to add thickness to a complex artery STL file? (Adding thickness in salome just crashes it.)
Thank You
sangeet is offline   Reply With Quote
artery, foam-extend-4.0, fsifoam
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
