July 9, 2018, 03:41 |
CD coefficient for a Sphere at Re=1e+7
Danny
Rep Power: 7 |
i'm trying to simulate a 3D-Sphere in water at Reynolds Number 1e+7 (i.e. 10'000'000) in Star-CCM+, but at the moment i'm not achieving the correct CD result of about 0.19. My physics options are: Velocity Inlet V = 10.014 m/s Density rho= 998.6 kg/m3 Sphere Diameter D = 1m Turbulence Model = Spalart-Allmaras Time = Steady Fluid Type = Liquid. The Mesh options on the body are: Number of Prism Layer = 20 Thickness of the first element = 1e-7m Prism Layer thickness = 1cm Can someone please help me? Some advices are appreciated. I really appreciate much. P.S K-w and K-epsilon have not shown any convergence -Danny- |
July 9, 2018, 09:47 |
Matt
Rep Power: 17 |
Is this steady or unsteady?
July 9, 2018, 09:48 |
Danny
Rep Power: 7 |
July 9, 2018, 09:56 |
Matt
Rep Power: 17 |
At that Re your flow is going to have an unsteady wake. Change your simulation over to unsteady and give it an appropriate time step, you should see at least some improvement. You will want to make sure that you setup a plot or data file of cd vs time so you can extract the oscillating drag value over a few periods after it has 'converged'.
July 9, 2018, 10:20 |
#5 | |
Danny
Rep Power: 7 |
July 9, 2018, 10:21 |
Matt
Rep Power: 17 |
Then you should expect to get the wrong drag value.
drag coefficients |
Error in Drag Coefficient for 3D sphere | scyllakeeper | FLUENT | 0 | June 7, 2016 08:22 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
