subhankar
Rep Power: 10 ![]() |
How to specify the axial and radial component of flow direction? Does the sum of the above two components of flow direction has to be one? Does it take the tangential velocity into consideration?
For example I am giving tangential velocity equal to 1 m/s and the axial and radial components as 0.7 and 0.3 respectively? Are the following specifications correct? If my inlet is an annular cross section revolving around x-axis, then what should be the components of the axis origin? |
swirl inlet velocity for a 2-d axisymmetric flow | zahrarashidi | OpenFOAM Running, Solving & CFD | 2 | January 12, 2015 07:01 |
Looking for tutorials relate to combustion flow in liquid rocket engine | Thet Nyi Nyi Shwe | CFX | 2 | December 9, 2014 13:09 |
swirl flow | rvndr | FLUENT | 10 | May 30, 2012 02:53 |
swirl (number) in jet flow | N.A.Beishuizen | Siemens | 0 | July 6, 2001 08:23 |
Combustion Flow Simulation in the Incinerator | Jin Wook LEE | Main CFD Forum | 5 | July 26, 1999 20:07 |
