December 22, 2018, 22:44 |
Sponge layer in incompressible LES
Peter Shi
Rep Power: 9 |
Hi all,
I am using incompressible LES to study airfoil-self noise. I am wondering, do I need to have sponge layers in this case? I feel like the sponge layer is needed in compressible LES solvers, but not sure about the incompressible solver. Would like to hear any inputs. Thank you. Best regards, Peter |
December 28, 2018, 12:54 |
Lucky
Rep Power: 66 |
Sound is due to compressibility... Why are you doing incompressible LES? Am I missing something here?
Sponge layers are used for damping out unwanted fluctuations for various reasons. You may or my not need it for your problem. For example a fixed pressure boundary at an outlet reflects pressure fluctuations back into the domain and can lead to numerical issues. A sponge can be used to damp out these fluctuations as a compromise and allow the fixed pressure boundary condition to still be applied without the unwanted reflection. |
December 28, 2018, 13:01 |
#3 | |
Peter Shi
Rep Power: 9 |
Instead, if you use incompressible LES, you calculate the near field pressure fluctuations first, then use FW-H to compute the far field noise. It is a hybrid method, which saves you a lot of time In my case, my Mach number is very low, the flow is almost incompressible. Therefore, I use incompressible LES. Hope my explanation makes sense to you. Best, Peter |
December 28, 2018, 13:13 |
#4 | |
Filippo Maria Denaro
Rep Power: 71 |
Maybe you are referring as to the generation of inflow conditions for LES? In such a case, you should read about the method of Kaltenbach, illustrated in Sec.10.3 of the Sagaut's book. |
December 28, 2018, 14:18 |
#5 | |
Lucky
Rep Power: 66 |
Okay now I follow you. So you using LES to obtain the background flow and model the noise separately. Well then you probably don't need a sponge. You don't really have this reflection problem in incompressible LES. I'm trying to think of what you would need/want to damp out in incompressible LES and nothing comes to mind (right now). |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
LES boundary layer | ignacio | OpenFOAM Running, Solving & CFD | 0 | May 6, 2013 05:14 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
sponge layer | shuo | Main CFD Forum | 0 | April 1, 2010 00:39 |
