Asymmetric Results from Simple Diffusion Problem |
February 22, 2019, 11:36 |
Raunak Bardia
Rep Power: 11 |
I am using OpenFOAM v1706 and trying to make some additions to the interFlow solver. I have initialized a field that is concentrated at the interfacial cells of my two-phase system. It is shown by the attached image (InitialCondition.jpg). I use a simple diffusion equation to diffuse this field on the rest of the grid. The result is shown in the second image (Diffused.jpg). Clearly, the circular symmetry is lost and it has to be due to some error in my implementation of the diffusion equation. But the volume integration of the initial source is conserved to the tolerance level that was specified. Here is my source code used for the diffusion equation spreadSource.H Code:
const dimensionedScalar mdotDiffusionConstant("diff",dimArea,dict_.lookupOrDefault<scalar>("mdotDiffusionConstant",1000)); mdot1 = mdot0; // mdot0 stores the initial condition fvScalarMatrix mdotSpreadEqn ( fvm::laplacian(mdotDiffusionConstant, mdot1) ); mdotSpreadEqn.solve(); createFields.H Code:
// Calculating Source Term at Interfacial Cells volScalarField mdot0 ( IOobject ( "mdot0", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("zero",dimensionSet(1,-3,-1,0,0,0,0),0.0) ); // Distributing Source Term in the domain volScalarField mdot1 ( IOobject ( "mdot1", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedScalar("zero",dimensionSet(1,-3,-1,0,0,0,0),0.0), mdotBoundaries ); fvSolution Code:
solvers { "alpha.water.*" { interfaceMethod "isoAdvector"; isoFaceTol 1e-8; surfCellTol 1e-8; snapAlphaTol 1e-8; nAlphaBounds 3; clip true; writeIsoFaces false; writeInterfaceDetails true; phaseChange true; prescribedmdot true; massfluxvalue -100.0; nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; mdotDiffusionConstant 6.25e-08; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-10; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; tolerance 1e-07; relTol 0; } mdot1 { solver PCG; preconditioner DIC; tolerance 1e-8; relTol 0.1; } mdot1Final { $mdot1; } U { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; } } PIMPLE { momentumPredictor no; nCorrectors -1; nNonOrthogonalCorrectors -1; nAlphaCorr 1; nAlphaSubCycles 1; cAlpha 1; pRefCell 0; pRefValue 0; } SIMPLE { nNonOrthogonalCorrectors 0; } Thanks. |
diffusion equation, interflow, isoadvector, openfoam |
Problem using FVM, SIMPLE algorithm | Elay | Main CFD Forum | 0 | July 3, 2014 16:39 |
Simple Impinging Fountain problem | MarkK | CFX | 4 | February 5, 2011 05:30 |
Simple melting problem | wawa | FLUENT | 0 | January 28, 2011 12:19 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
? Simple CFD problem | Davy | Main CFD Forum | 0 | August 21, 1998 06:19 |
