Try to understand the practice of under-relaxation |
February 26, 2019, 02:41 |
CHEUNG WING KI
Rep Power: 9 |
Dear all member,
Greetings guys, I've been reading "An Introduction to Computational Fluid Dynamics: The Finite Volume Method" to get some basic concept of how SIMPLE algorithm works. I read about the section of under-relaxing the linked coefficients, velocity field from previous iteration. It also says *the under-relaxation is used from the start of the calculation*. My questions are, 1. Is the under-relaxation applied at the 1st iteration (like applying to coefficient Ap)? 2. Is it necessary that the sum of pressure relaxation factor and velocity relaxation factor equals to 1? Thanks, Rick |
February 28, 2019, 03:39 |
#2 | |
Vignesh Rajendiran
Rep Power: 9 |
2. No it is not necessary to keep it as 1 (It is a good common practice). You can run the simulation even without the under-relaxation factors hoping to get a solution. |
March 2, 2019, 20:37 |
#3 | |
CHEUNG WING KI
Rep Power: 9 |
under-relaxation |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
best practice for relaxation factor in buoyant driven flow. | wanggl | OpenFOAM Running, Solving & CFD | 3 | January 2, 2018 01:36 |
About equation relaxation | chriss85 | OpenFOAM Running, Solving & CFD | 1 | May 2, 2017 19:52 |
Relaxation and convergence | sammi | Phoenics | 0 | March 20, 2008 03:32 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
